| Message |
hi Z crews . i have a 1990 TT , 5 speed , the only problem i having after i did my timing belt . it has a vacum leak somewhere but still trying to find it but notice when the motor is idling .. it revs up n down under 1 rpm . when motor is warm up its barley stays between 0 an 1 rpm. other then all this issue, i decided to unplug the mass flow sensor the motor starts to rev in all 6 cylinders n rev smooth means motor not shaking. now i plug it back it shakes and sounds like a bad missing power. what can i do ? do i need a new mass flow sensor or adjust it ? thanks .
